Scuderia Ferrari SF15-T
Re: Scuderia Ferrari SF15-T
Abarth wrote:
Artur Craft wrote:
turbof1 wrote: Ferrari always had less traction the Mercedes; that has been since winter testing apperent. Expect it to be very noticable in Monaco.
Didn't seem to be the biggest problem in other places like Sepang where Vettel was the fastest/cofastest on S1/3 but was almost 0,6s down on Rosberg's S2(Vettel only used Primes on Sepang's qualifying). Previously, Ferrari's biggest gap was on downforce sectors. In Barcelona, it turned out the opposite. They were no more than a couple of tenths down on S1/S2(where the mid-high speed corners are) but 0,45s down on S3
Before Barcelona, I was expecting Ferrari to be a real threat in Monaco but, now, I think Mercedes will easily walk again.
This is indeed strange. Kimi in the old configuration in his fastest S3 was much faster than Vettel. Edit: And in Qual, he was on par with Vettel in the last sector, but losing heavily in S1 and esp. in S2.
How can you improve Aero and in the same time losing on slow traction bits of the circuit, I wonder?
Has the new aero changed pressure center, and required much different settings, eg. stiffer rear suspension, worsening traction?
Hmm maybe track conditions changed or driver differences. Arrivabenne said the updates were indeed working much better than the old parts during the race.
Crucial_Xtreme
Crucial_Xtreme
404
Abarth wrote: This is indeed strange. Kimi in the old configuration in his fastest S3 was much faster than Vettel. Edit: And in Qual, he was on par with Vettel in the last sector, but losing heavily in S1 and esp. in S2.
The team has said the numbers prove the updates were working. In the heavily aero dependent parts of the track the updated car worked well and better than the old configuration. S3 could be down to each driver but it's possible that with the updates the car has better downforce but the updates are new so the team hasn't had time to fully dial in/optimize the setup, whereas with the old config the setup is definitely optimized and the low speed traction and mechanical grip work previously done showed. I think they just need time to optimize the setup of the new updates.
atlantis
atlantis
21
Looking (again) at a few Raikkonen's onboards, it seems the car had too much understeering.
Maybe they tried to compensate with more front wing but probably that exacerbated the rear instability.
atlantis
atlantis
21
If I had to say something about the engine, I'd say it looks like a bit too "pointy" compared to Mercedes, which seems more smooth and constant in power delivery.
f1316
f1316
82
If you're talking about race sector times, kimi was on the softer compound at the end of the race (when fuel was lowest) whereas Seb was on the hards. I'm pretty sure all kimi's best sector times were faster but it's for this reason.
As you say, in quali s3 the same but much slower in 1 and 2; shows no negative effect of updates but positive in high speed stuff.
Jv12
Jv12
This weeks Barcelona test will surely allow Ferrari to optimize the new aero package and updates.
Gallery DAY 1 Test Barcellona
Click here
http://www.newsf1.it/test-barcellona-1-day-foto3112/
Forza
238
F1 Testing 2015 - Barcelona - Day 1
santos
santos
This guy must be really tall. He almost blocks the air scoop.
Webber2011
Webber2011
Ok, a question from someone not as knowledgeable as all you good folk.
I'm really enjoying learning about the way the aerodynamics work, and flow vis is my friend because it gives me a visual reference to a lot of the things discussed here.
I found this picture a little puzzling though.
http://img1.auto-motor-und-sport.de/Raf ... 863281.jpg
From what I can see they only applied the flow vis to the rear wing.
What would cause the, (for want of a better description), droplets or spattering on the bodywork above and in front of the exhaust ?
bhall II
bhall II
477
It's apparently not the tidiest stuff to work with.
Moose
Moose
52
Webber2011 wrote:Ok, a question from someone not as knowledgeable as all you good folk.
At a guess, the flow-vis was applied significantly upstream of the rear wing. To me, it doesn't look like it's been directly applied there. My bet is it's been applied to the leading edge of the side pods.
Formula 1 day 2 TEST BARCELLONA Esteban Gutiérrez
Webber2011
Webber2011
bhall II wrote:It's apparently not the tidiest stuff to work with.
http://i.imgur.com/L3kIiBD.jpg
Wow !
Thank you.
I didn't realise it was such a mess to apply !
twennyone
twennyone
I think they have applied flow vis on the floor before the rear wheels also (possibly a new strake in there?), as pictured in forza's quote below. Maybe it has spattered onto the rear of the engine cover during the lap.
Forza wrote:F1 Testing 2015 - Barcelona - Day 1
http://img2.auto-motor-und-sport.de/Raf ... 863296.jpg
Could be a different driver/lap, I'm not sure, would take a closer inspection, but just a possibility.
