iotar__ wrote:Of course you can as long it breaks the rules - like in Raikkonen's case in Abu Dhabi '13. They failed floor deflection test after missing the part on the kerb (that's your dynamic part). Did it happen? Yes. Accident? Of course but it didn't matter. Stewards can accept or ignore any explanation and apply a penalty because measurement X is out of range. Do you think they measured gains or team's guilt?
But Mercs didn't broke any rules and all relevant measurements were WITHIN defined range! The only measurement that was out of range was the one with cold tires on the grid - I'm sure tire pressure was within the limits on the start (after warm-up circle).
iotar__ wrote:... hard measurement is a hard measurement.
Yes, but this was not "a hard measurement" - that's why they concluded that more defined measuring/controlling procedure/protocol is in order.
iotar__ wrote:Same here and A. difference in procedures does not work in Mercedes' favour (unknown area). B. It's safety and there's no compromises with safety, that didn't last long, did it?
![Wink :wink:](./images/smilies/icon_e_wink.gif)
Where did you get an info that Mercedes' cars were racing with "incorrect/unsafe" tire pressure? 19,5Psi criteria needs to be matched during the racing (between moment red lights went out and a checkered flag been waved).
Measuring/control protocol has not been thought trough, that's why no penalty was imposed.
iotar__ wrote:Evans is right his tyres were outside the range (reference point for penalties) and so was Mercedes'. They chose to ignore it based on a team and politics as always.
You are ignoring the facts and pushing forward a highly unlikely conspiracy theory.
