McLaren MCL33
cliffgamerz
cliffgamerz
Re: McLaren MCL33
Thats a common thing for rain setup to avoid aquaplaning.
Re: McLaren MCL33
k.ko100v
k.ko100v
Re: McLaren MCL33
Article regarding the rear suspension.
https://www.motorsport.com/f1/news/mcla ... l-1009835/
Re: McLaren MCL33
Via @f1writers
k.ko100v
k.ko100v
Re: McLaren MCL33
More from today
gambler
gambler
Re: McLaren MCL33
I would guess to take the "push" out... from the rain. I wonder how much raise and lower adjustment they have at their disposal? That looks like an inch if not more over normal.
JonoNic
Re: McLaren MCL33
It seems like the halo is disguising the size of the car. That McLaren would look even smaller without the halo.
ALO_Power
ALO_Power
Re: McLaren MCL33
Do we know if they kept the same body work (engine cover) for today as well? Because also Alonso's car today had the same "burn marks" and actually on both sides (on one side it's pretty dim tho).
3jawchuck
3jawchuck
37
Re: McLaren MCL33
ALO_Power wrote:
28 Feb 2018, 21:32
Very likely they did, no need to change anything that isn't broken and it is there from the first lap out.
AnthonyG
38
Re: McLaren MCL33
Morteza wrote:
28 Feb 2018, 18:45
https://pbs.twimg.com/media/DXIvv9hXcAAYzsk.jpg:large
Via @f1writers
A trailing edge flap on the engine cover?
It's not on all pictures of today.
adrianjordan
Re: McLaren MCL33
Regarding the holes in the floor either side of the sidepods. Could they have a raised section so that when you look from underneath there isn't a hole, but such that it channels air through the slots?
My laptop has died otherwise I would try and make a diagram to show what I mean.
Favourite team: McLaren
DFX
DFX
Re: McLaren MCL33
adrianjordan wrote:
28 Feb 2018, 22:55
Surely they are not holes and rather slots as you said. In a top down view we wouldnt be able to see the ground, or the light passing as some pointed out.
Although this is the mother of slots! :mrgreen:
jh199
32
Re: McLaren MCL33
DFX wrote:
28 Feb 2018, 23:04
adrianjordan wrote:
28 Feb 2018, 22:55
Heres that top-down view. The slots are very obvious in this view but I see what you're saying adrianjordan. Maybe when you center the camera over the car you can see the slots but when you center the camera over the slots they are covered. Like, they have a sort of scoop on the top side that'll grab the air and force it downwards while looking like a solid, continuous piece from directly above and below
roon
roon
412
Re: McLaren MCL33
McMrocks
McMrocks
32
Re: McLaren MCL33
I once posted the question as to wether how these slots in the floor are legal. There are no small cuts which would make the contour one homogenous line. So how it is legal?
