Thats a common thing for rain setup to avoid aquaplaning.the EDGE wrote: ↑28 Feb 2018, 16:01That's some rake their running
https://img.f1today.eu/x/full/photos/5a ... 2df457.jpg
https://img.f1today.eu/x/full/photos/5a ... 10601c.jpg
I would guess to take the "push" out... from the rain. I wonder how much raise and lower adjustment they have at their disposal? That looks like an inch if not more over normal.the EDGE wrote: ↑28 Feb 2018, 16:01That's some rake their running
Very likely they did, no need to change anything that isn't broken and it is there from the first lap out.
A trailing edge flap on the engine cover?Morteza wrote: ↑28 Feb 2018, 18:45https://pbs.twimg.com/media/DXIvv9hXcAAYzsk.jpg:large
Via @f1writers
Surely they are not holes and rather slots as you said. In a top down view we wouldnt be able to see the ground, or the light passing as some pointed out.adrianjordan wrote: ↑28 Feb 2018, 22:55Regarding the holes in the floor either side of the sidepods. Could they have a raised section so that when you look from underneath there isn't a hole, but such that it channels air through the slots?
My laptop has died otherwise I would try and make a diagram to show what I mean.
Heres that top-down view. The slots are very obvious in this view but I see what you're saying adrianjordan. Maybe when you center the camera over the car you can see the slots but when you center the camera over the slots they are covered. Like, they have a sort of scoop on the top side that'll grab the air and force it downwards while looking like a solid, continuous piece from directly above and belowDFX wrote: ↑28 Feb 2018, 23:04Surely they are not holes and rather slots as you said. In a top down view we wouldnt be able to see the ground, or the light passing as some pointed out.adrianjordan wrote: ↑28 Feb 2018, 22:55Regarding the holes in the floor either side of the sidepods. Could they have a raised section so that when you look from underneath there isn't a hole, but such that it channels air through the slots?
Although this is the mother of slots!
