This is not a subtle nuance, it's plain to see for the most causal observer
Impressive laptime it is then.Juzh wrote: ↑07 Sep 2019, 18:42leclerc vs vettel q3 lap - vettel with no one if front. leclerc +10 kph on every straight
https://streamable.com/nzpbx
Which is why we had so much ‘No please after you!’. Those calling for Hulkenberg, Sainz and Stroll being penalised are missing 1 clear point. If Hamilton, Ricciardo, Vettel, LeClerc, Albon Or Bottas has been in that position it would have been exactly the same. Nobody wanted to be at the front and as such leaving it that late was idiotic.Juzh wrote: ↑07 Sep 2019, 18:42leclerc vs vettel q3 lap - vettel with no one if front. leclerc +10 kph on every straight
And Seb couple kph in every corner as well. While you gain on straights with a tow, and get net benefit (F1 said up to 0.2 seconds), you do lose in corners compared to no tow so net benefit is not no tow lap + tow difference.Juzh wrote: ↑07 Sep 2019, 18:42leclerc vs vettel q3 lap - vettel with no one if front. leclerc +10 kph on every straight
Restomaniac wrote: ↑07 Sep 2019, 18:20Obviously but then again you can’t see that everyone getting to turn 1 with only 1’36 (including tyre warm ups and creating space) left on the clock was insane so..........
And if they were in those positions they should get penalties.Restomaniac wrote: ↑07 Sep 2019, 18:50Which is why we had so much ‘No please after you!’. Those calling for Hulkenberg, Sainz and Stroll being penalised are missing 1 clear point. If Hamilton, Ricciardo, Vettel, LeClerc, Albon Or Bottas has been in that position it would have been exactly the same. Nobody wanted to be at the front and as such leaving it that late was idiotic.Juzh wrote: ↑07 Sep 2019, 18:42leclerc vs vettel q3 lap - vettel with no one if front. leclerc +10 kph on every straight
Part 1 I agree with as I have already told you.dans79 wrote: ↑07 Sep 2019, 18:54However going off track without a valid reason is against the rules, as is blocking other drivers.Restomaniac wrote: ↑07 Sep 2019, 18:20Obviously but then again you can’t see that everyone getting to turn 1 with only 1’36 (including tyre warm ups and creating space) left on the clock was insane so..........
So they should get the penalties because they just happened to blink first. Yeah okdans79 wrote: ↑07 Sep 2019, 18:55And if they were in those positions they should get penalties.Restomaniac wrote: ↑07 Sep 2019, 18:50Which is why we had so much ‘No please after you!’. Those calling for Hulkenberg, Sainz and Stroll being penalised are missing 1 clear point. If Hamilton, Ricciardo, Vettel, LeClerc, Albon Or Bottas has been in that position it would have been exactly the same. Nobody wanted to be at the front and as such leaving it that late was idiotic.Juzh wrote: ↑07 Sep 2019, 18:42leclerc vs vettel q3 lap - vettel with no one if front. leclerc +10 kph on every straight
