I think a more objective way is ‘did everyone see the car move?’ To which the answer is ‘yes’. Ergo jump start.Roman wrote: ↑14 Oct 2019, 09:49The rules in case of the "VET jump start" are quite clear and simple:
FIA Formula One Sporting Regulations (Google 2019 FIA Formula One Sporting Regulations), Article 36.13 states:
Therefore, if the sensor didnt detect a movement it's not a jump start.[...]
Either of the penalties under Articles 38.3c) or d) will be imposed on any driver who is judged
to have :
a) Moved before the start signal is given, such judgement being made by an FIA approved
and supplied transponder fitted to each car,
Honestly, I prefer such a measurement as opposed to human judgement as human judgement will always be flawed and this is an objective way to measure jumps starts.
If FIA now decides this rule needs a change or clarification then they can do so, but only for the remainder of the season, not for races that already happened. For the moment there is no room for any kind of conspiracy theories mentioned here by several users.
As mentioned above- the sensor should be there to be used to compliment the plain video evidence (when there might have been movement but you can’t be sure from the footage) rather than over rule or contradict it. Which makes it look completely like they were just finding an excuse not to penalise him.
It’s ridiculous where on two consecutive races there has been a jump start and one driver got punished but the other did not. So you’re right in that there needs to be consistency.
