Red Bull RB19
Re: Red Bull RB19
Pretty sure that Max's wing was trimmed deeper (based on how close to the edge the ORACLE logo is) but then there was more left behind the actuator..
we can see the white lettering of the ORACLE logo on Max's wing goes to the edge whereas on Perez's car it doesn't in the pic below
Juzh
161
Re: Red Bull RB19
Good spot. Verstappen's wing is indeed cut deeper. Actually both steps are deeper than perez' straight cut. Second cut on verstappen's car is visibly lower. Must be the reason for that strange looking DRS support in the middle.
Didn't seem to help verstappen much in passing sainz.. Perez had pretty much same top speeds everywhere. Must be DRS effect was equal on both cars.
Re: Red Bull RB19
Juzh wrote: ↑
06 Sep 2023, 15:45
It's usually assumed that Verstappen has more front flap angle which is draggier. We've seen a season long trend usually when they both have the same rear wing, that Perez is typically about 2km/h quicker on the longer straights.
A lion must kill its prey.
vorticism
323
Re: Red Bull RB19
There's nothing in the regs to stop rake from increasing in coming seasons. I wonder if that could be a scope of development once floors are fully sorted.
π“„€
Re: Red Bull RB19
organic wrote: ↑
06 Sep 2023, 15:39
https://imgr1.auto-motor-und-sport.de/R ... 033432.jpg
Could that be just a difference of rear load to help give Perez some confidence in the car? A little more rear end for Perez compared to Max. Max then also running a touch more front wing to give the front end that maximises the car.
Re: Red Bull RB19
Just_a_fan wrote: ↑
11 Sep 2023, 16:31
organic wrote: ↑
06 Sep 2023, 15:39
Yeah I think in this case that's very likely it's mostly down to driver feel
Re: Red Bull RB19
New rear-wing endplate corner, in the style of many other high downforce RWs on the grid (AMR, Merc, Alpha Tauri, Alpine, McLaren)
The design keeps reappearing but only in the high downforce configurations at monaco, singapore etc. Clearly results in greater max downforce config
Gurney flap also fitted!
Albert Fabrega πŸ“Έ
:P
organic wrote: ↑
25 Aug 2023, 07:03
Expect next update in singapore then. Cheers Marko.
Considering the general trend with high df wings up and down the field I'm going to assume that these new endplate styles are the way forward, at least for low efficiency tracks. Singapore's one of those and I feel this sort of endplate trick could be easily/cheaply be copied by RB for their next upgrades. Wouldn't expect much from the Singapore upgrade apart from that
organic wrote: ↑
28 Aug 2023, 04:23
Marko mentioned rb's only upgrade would come at Singapore. I suspect it will be rear wing endplates and a floor edge tweak
Re: Red Bull RB19
organic wrote: ↑
14 Sep 2023, 10:21
Albert Fabrega πŸ“Έ
https://i.imgur.com/hvUaxJZ.png
https://pbs.twimg.com/media/F5-P6IkbIAA ... me=240x240
:P
organic wrote: ↑
25 Aug 2023, 07:03
organic wrote: ↑
28 Aug 2023, 04:23
Has the boss that holds the flap pivot always been oriented sideways like that?
Re: Red Bull RB19
AR3-GP wrote: ↑
14 Sep 2023, 14:34
organic wrote: ↑
14 Sep 2023, 10:21
Albert Fabrega πŸ“Έ
:P
organic wrote: ↑
25 Aug 2023, 07:03
organic wrote: ↑
28 Aug 2023, 04:23
OK bear with i investigated:
sideways
Bahrain 2023:
Baku
Monaco
Barcelona
Canada,Austria - sideways as before
Silverstone
Hungary - it changes
So for Hungary it changes to a diagonal orientation for the DRS flap pivots but only for the high DF wing. The low DF wing at Monza still had horizontal pivots. [1] [2]
At Zandvoort and now for Singapore they have the diagonal pivots
Zandvoort
Singapore
It's just about reducing induced drag I think
Re: Red Bull RB19
2 for 2 :shock:
organic wrote: ↑
28 Aug 2023, 04:23
Re: Red Bull RB19
vorticism
323
Re: Red Bull RB19
organic wrote: ↑
15 Sep 2023, 09:58
2 for 2 :shock:
Well done. 8)
π“„€
Re: Red Bull RB19
RB19 for Suzuka again with the new floor edge wing which was run in Fp1/Fp2 at Singapore.
Re: Red Bull RB19
Big opening to diffuser...
ThijsMuis
ThijsMuis
Re: Red Bull RB19
