Red Bull RB20
Stu
Re: Red Bull RB20
Very interesting cooler layout.
V- shaped coolers in sidepod, lower one looks to have its outlet very shrouded (would be enlightening to see it from above).
Twin coolers being fed by the cockpit/halo inlet.
It also looks like a cooler placed directly above the V of the engine (could that be a charge-cooler, possibly with the halo coolers on the wet-side for a very short pipe run). There certainly looks to be pipework running to/from it.
Re: Red Bull RB20
Andi76 wrote:
22 Feb 2024, 08:49
Or my fault for not realizing it :lol: - but don't you think Red Bull's Sidepods are going in that direction? The shape and everything else reminds me a lot of it when you compare it to the STR06.
The whole sidepod is angled downwards and I suspect it will remain so. This aids downwashing in the rear and outwashing in the front, both of which induce lift locally.
CaribouBread
CaribouBread
101
Re: Red Bull RB20
Bumpy calipers again (c. Fabrega)
beerjoystick
beerjoystick
Re: Red Bull RB20
Stu wrote:
22 Feb 2024, 08:44
The high central coolers are more auxiliary units, water and oil. Charge air are the ones on the floor of the sidepod
Re: Red Bull RB20
Rb20 calipers in pic 1
AMuS photos
Floor edge wing etc
michl420
michl420
Re: Red Bull RB20
I would asume the vertical inlet goes to the sidepod cooler. The horizontal inlet looks to small to allow enough air. Just an assumption.
Re: Red Bull RB20
Floor edge details
via ams
Mattchu
58
Re: Red Bull RB20
Re: Red Bull RB20
outlet has been there relatively unchanged since launch spec rb18. Other teamms have had outlets there and got rid of them too eg f1-75. internal ducting might've changed in the area though
vorticism
323
Re: Red Bull RB20
Of all the parts on the launch car, only two were fake:
Mmgnt wrote:
19 Feb 2024, 03:20
Unless they can block those inlets off during cold weather.
𓄀
Re: Red Bull RB20
miguelalvesreis
miguelalvesreis
Re: Red Bull RB20
vorticism wrote:Of all the parts on the launch car, only two were fake:
Mmgnt wrote:
19 Feb 2024, 03:20
Plus the vanity panels on top of the sidepods
Enviado do meu RMX3572 através do Tapatalk
vorticism
323
Re: Red Bull RB20
Simon Galloway / motorsport.com
22 Feb 2024, 11:11
They're tested the rear louver panel both open and closed. The inner valley louver panel probably has the same function as the rear panel; typical engine cover vent i.e. not dedicated ducted paths.
Screenshot from: https://x.com/dr_obbs/status/1760198642634314001?s=20
𓄀
Re: Red Bull RB20
Seems the gullies have not only the louvres but a large outlet there as well. Markup not by me
Did the car run on track like this? :shock:
chrstphrln
Re: Red Bull RB20
Apparently Newey was inspired by Ferrari.
