2024 Mexican Grand Prix - Autódromo Hermanos Rodríguez, Oct 25 - 27
Tyre selection
C3 - C4 - C5
2023 Results
Qualifying
Race
2023 Pole Lap
2023 Race Highlights
Schedule and more information
bananapeel23
Re: 2024 Mexican Grand Prix - Autódromo Hermanos Rodríguez, Oct 25 - 27
What are we expecting in terms of the pecking order here? I have lost any grasp of the strong points of the different cars. Ferrari suddenly seems great in all corner types and so does McLaren and to a lesser extent Red Bull. Is this likely to be a PU-dependent race. If so, Is the high altitude likely to negatively impact Ferrari more than the competition due to their smaller turbo?
Personally I'm guessing performance will be very close, with the cars probably being so close that car performance becomes secondary to driver skill. Still I'd imagine the pecking order being:
1. Ferrari (should be amazing in turns 4-6 and 12-16, probably slightly worse elsewhere)
2. McLaren
3. Red Bull
I reckon Norris or Verstappen sticks it on pole again, Ferraris around 2-5 with Piastri. Perez either P8 or out in Q1. If it ends up really warm like in COTA, Ferrari should be the favourites as long as their engine (turbo) doesn't struggle with overheating in the thin air and they don't get stuck behind someone.
basti313
basti313
bananapeel23 wrote:
21 Oct 2024, 14:09
I think they are quite similar, you can not just separate strong and weak points.
The only thing obvious is, that the 90° corners will make RedBull suffer on understeer again. So my bet would be again on a close fight between McLaren and Ferrari.
bananapeel23 wrote:
21 Oct 2024, 14:09
Are we expecting this to be a race that is determined by PU supplier?
No, I think everyone learned how to deal with the height. The last years there was no obvious deficit, only what you mention with Ferrari, but that was solved.
Don`t russel the hamster!
McLaren/Ferrari>Red Bull>>Mercedes pretty much, unless McLaren does a floor downgrade in Mexico
Haas looking great lately, should be able to extend P6 lead in WCC
basti313
basti313
Vanja #66 wrote:
21 Oct 2024, 16:32
Yes, you can add them to the list. So points are all set =D>
Now, what happens if Perez?
Who snatches the points of the top 10 if anyone in our top 10 list crashes? RB or Willi? Colapinto or Lawson?
Perez' last realistic chance to win his home race.
dialtone
dialtone
122
PlatinumZealot wrote:
21 Oct 2024, 22:39
He's in for a good F1.5 showing perhaps but Haas looks stronger.
search
not sure the low-grip track suits Ferrari particularly well - but I honestly didn't expect COTA to do either. Difficult to say who may have an advantage.
Paa
21 Oct 2024, 22:39
Realistic?
bananapeel23
search wrote:
21 Oct 2024, 23:29
Isn't low grip good? Low grip = a lot of sliding = more tyre overheating, which is something Ferrari is less prone to than the competition. Ferrari is also just good under traction, and more sliding means more time under traction.
One of the worst tracks to start on pole.
If it's hot i can see Ferrari having the pace advantage on sunday.
F1NAC
172
21 Oct 2024, 22:39
I was going to say coming into this thread, I'm expecting him announcing his retirement. Time is up.
DGP123
DGP123
Sevach wrote:
22 Oct 2024, 05:25
Yep. Should be one big name victim coming out of the T1/2/3 chaos on lap 1
It’s usually a borefest from then on.
venkyhere
venkyhere
Sector1 has two big straights and a chicane.
And everyone is going to run high wing levels. Will be a good testing ground for 'aero-efficiency'.
Big kerbs and slow speed sharp turns relegates Redbull to 4th fastest. Mercedes is unpredictable, even they don't know where they are, after their newest updates (Russel ran a good race in COTA using 'older' parts, didn't he?).
That leaves it to be a clear dogfight between McLaren and Ferrari, both of whom, like slow turns and straights, and are good with lower gear traction.
Formula 1 fan 1996
Formula 1 fan 1996
Russell will drive with older parts in Mexico, while Hamilton will drive with new parts?
