peewon wrote: ↑28 Sep 2024, 11:42
Jambier wrote: ↑26 Sep 2024, 20:47
As said before, the ICE will not change that much for 2026, I don’t see many risks there
Well its not necessary they change but they could. The min. weight is lower so teams would want a more efficient and lighter PU. A more powerful ICE can significantly reduce the limitations expected with significantly higher percentage of battery power.
They're not having problems meeting weight now? RBR said they were 20KG over weight the first year of current regs. You don't think if they could have made the PU lighter, they wouldn't have? Hell, most cars ran without paint!
Weight is time in F1 So everything is as light as can be. Even being under weight is an advantage. It allows you to put ballast exactly where you need it to improve handling.
