Well, I'm no tyre expert either, but it strikes me that the tyre sidewall is pretty important in channelling these gases to where they need to be in the EBD. If the sidewall is moving about more than it did this year, then they will need to ensure there is enough clearance between it and the floor and this clearance will also vary more dynamically. I suspect this will cause performance from the EBD to be less predictable.
Now, maybe you're right that the top teams will get more benefit from the system becoming more complicated to understand, but my argument is that this is likely to cause a reduction is performance generally from the EBDs, reducing their relative importance.
