TAG wrote:Curious to know how a .3 PSI difference on ONE tire is an advantage. Curious to know if it's approved by Pirelli when it's being filled and it's lower when it gets to the grid how there's anything anyone can do about it. Curious to know how they know an issue exisist yet allow just about the entirety of a race to go on before a descision is made to notify Mercedes that they're under investigation.
If their rear wing was longer by 0,3 cm asymmetrically (or whatever
![Smile :)](./images/smilies/icon_e_smile.gif)
) would you be asking about the amount of downforce it gave them and lap advantage or would it be an automatic DSQ? Would you be saying it didn't matter because they're winning anyway? No. Merc arguing about advantages of .3 PSI is only marketing.
Repeating time, order is important:
- did Merc start with pressure outside of recommended range as measured and stated in FIA document or not?
- does said pressure affect state of the tyres and therefore the safety in connection with performance at any time in the race (stressing any)? Yes, that's why it was put in place and that's why stopping Merc in the race argument exists. No later monitoring or earlier (no) blankets measurements can change that. No guilt either. "Well Pirelli measured it so it's OK" There's no place for that in races.
- only now can it be a matter of applying penalties, they only got away because of the name, it was about a race win and would have resulted in another tyres and FIA controversy, better avoid that.
It doesn't matter, boring race anyway, season is over and everything is set. Massa got a podium again and not Bottas.
